Activity Forums Maxon Cinema 4D Cinema 4d 11.5 Aec File Troubles – Can’t import into aec files into After Effects
  • Cinema 4d 11.5 Aec File Troubles – Can’t import into aec files into After Effects
    Posted by Dave Glanz on September 18, 2009 at 9:03 pm
    Hey all,
    So we upgraded to Cinema 4D 11.5 here this week, and for whatever reason, After Effects (CS4) won’t import any AEC files. Can anyone think of a reason why this might be happening?
    Currently using a quad core intel mac, Leopard 10.5.8. The C4D.plugin is in the same directory it was when I was using C4D 10.5 (After Effects/plugins/).
    Any help is greatly appreciated.
    *edit*
    Here’s my workflow:
    Cinema 4D – create object, attach an ‘External Compositing’ tag to the object. Add a camera, a couple lights, add a simple camera move. In Render Settings, I’m outputting a simple Quicktime file, have “Save” checked under “Compositing Project File” and “After Effects” as my Target Application. I also have the “Include 3D Data” checkbox checked.
    In After Effects > Import, I select the AEC file. Nothing happens. No errors. No files. It worked fine with C4D 10.5. I’m sure I’m missing something here. I’m using the plugin from here: https://www.MAXON.net/en/downloads/updates-…es/plugins.html
    Anyone else have this problem? If not, I’ll call MAXON on Monday.
    Here’s a simple test-
    https://dropbox.teamgroup.tv/data/dave/aec-test.zip
    Ste Kerouac replied 16 years, 5 months ago 5 Members · 4 Replies
  • Steven Jenkins
    September 19, 2009 at 9:18 pm
    Make sure you have latest version of the aec importer installed in the ae plugins folder.
  • Jonathan Wiley
    October 23, 2009 at 3:12 am
    Yup, you have to update the plugin. You should find it here:
    https://www.maxon.net/en/downloads/updates-co/updates/plugins.html
  • Jacob Genen
    March 22, 2010 at 5:05 pm
    Im having the same problem, I have up dated every thing.
    What should I do?
    _jake
  • Ste Kerouac
    March 30, 2010 at 11:47 pm
    I’ve been having this same problem…with both C4D 11.5 and 11.523.
    Latest version of AE CS4, and the exchange plugin. The same .c4d scenefile – aec will work if exported from v11 but not v11.5x
    But not everyone is experiencing this, so I have no idea what is causing it.
