Activity Forums Adobe Premiere Pro Cineform videos in Adobe Premiere Pro CS4
  • Cineform videos in Adobe Premiere Pro CS4
    Posted by Andrew Jackson on March 5, 2010 at 1:26 am
    HELP!
    I went from using Adobe Premiere Pro CS3 editing a film in 24p 720×480 videos. Than we wanted to up-res the videos to make it high def. So we went with Cineform Prospect 2k and made all the videos into 1920x1080P videos. And we put it all back together in premiere pro cs3. Than for some dumb reason, i upgraded from CS3 to CS4. I sadly regret it.
    Anyways, now whenever I try to open the project, everythng opens fine (sound, pictures, etc.) except the videos. It shows the message of the videos being offline. Than i try to replace the files with the videos, and it gives me the message “Dimensions (width/height) too large”.
    So now i can’t even finsh what i have started, although i have a deadline. I’ve tried many things, but no luck. Maybe someone can give me some advice that will benefit me.
    Also, i am running Windows 7.
    Thanks in advance for anyones input.
    -Andrew J.
    wfeditor@ymail.com
    Tim Kolb replied 16 years, 6 months ago 3 Members · 2 Replies
  • Brian Louis
    March 5, 2010 at 3:26 pm
    [Andrew Jackson] “i upgraded from CS3 to CS4. I sadly regret it.”
    You should always complete a project with the system you started with, there is nothing wrong with CS4, but when moving projects between versions minor differences can cause headaches depending on how the complex the project is.
  • Tim Kolb
    March 6, 2010 at 4:47 am
    many third party vendors never really dialed in CS4…
    Did you save the CS3 project? Typically Adobe apps like PPro and AE make a new file to advance versions…the old project for CS3 should still exist somewhere.
    …and of course, you’d be best served by going back to CS3.
    TimK,
    Director, Consultant
    Kolb Productions,
