Activity Forums Adobe Premiere Pro Cineform Neoscene and CS5
  • Cineform Neoscene and CS5
    Posted by Rey Morales on February 19, 2011 at 11:42 pm
    Is Cineform Neoscene needed anymore now that PPro CS5 pretty much reads all different types? Is it good to still have/use or completely unnecessary? Does anyone suggest now the practical usage for it now is to convert 1080p to 720p for faster workflow?
    Thinking about purchasing it, but do I need it now that CS5 does all format?
    -Rey Morales
    Steve Brame replied 15 years, 7 months ago 4 Members · 4 Replies
  • Steve Brame
    February 20, 2011 at 1:07 am
    I’ll say that we have all but stopped using Neoscene since we installed CS5. We primarily used it to transcode AVCHD footage, and CS5 handles that file type easily on our machine.
    Steve Brame
    creative illusions Productions
  • Ann Bens
    February 20, 2011 at 12:58 pm
    Download the trialversion of Neoscene and see of its any good. I love it.
    Not everybody has a smooth edit with AVCHD with CS5. It also depends on the machine you are running on.
  • Tim Kolb
    February 20, 2011 at 2:26 pm
    I’d say that PPro CS5 has the ability to recognize and edit AVCHD/DSLR footage, but the hardware you have needs to have the ability.
    CS5 is great, but it’s a box (or a download) of potential…
    You can’t put a fighter pilot in a Piper Cub and go into a dogfight…you need the machine that’s built for the job too.
    CineForm’s products not only bridge the gap for formats that are tough to edit…they also help machines that might be a couple years old respond much better as their codecs are not only very high quality, but optimized to run on computer CPUs from the start.
    Depending on your hardware configuration, CS5’s capability to handle some of these formats probably won’t translate into the same edit performance while you’re cutting. All this doesn’t take into account that color correcting 8 bit camera footage won’t be as nuanced as color correction on 10 bit CineForm footage (even if it’s converted from that very same 8 bit footage.)
    …I might do some testing before I wrote off CineForm just yet.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Steve Brame
    February 20, 2011 at 2:56 pm
    Absolutely correct! We did such testing for a little over 6 months before we stopped using Neoscene on our CS5 PC. I wouldn’t label our editor a ‘muscle machine’, and it seems to handle AVCHD media quite easily. Just like anything, you can either put your money into a system up front to prepare it for what you need it to do, or you put money into it after the fact to get it to do what you need it to do. And in our business, transcoding time IS money.
    Steve Brame
