Activity Forums Apple Final Cut Pro Legacy Chromakey and such
  • Chromakey and such
    Posted by Peter Litwinowicz on February 10, 2009 at 9:50 pm
    NOTE: GEEK ALERT 🙂
    So, I have a question for all you FCP pros out there. I’m using the chromakey filter on some green screen footage. Cool enough.
    However, if I follow the chromakeyer with FCP’s Gaussian Blur (in RGB+Alpha mode) with a large filter radius, then the green color, presumably in the areas that have been filtered out (by having the image areas set to zero or near-zero alpha), comes back into the blurred image.
    Which leads me to believe that the chromakeyer FCP just sets the alpha channel of the image without actually converting the image to a premultiplied state, even though internally all filters are supposed to work with premultiplied images (like FCP’s Gaussian Blur). THis causes the Gaussian Blur of FCP to not behave properly, because it appears the chromakeyed image creates a “straight” image instead of a premultiplied to be passed to the next filter, the Gaussian Blur, which is expecting a premultiplied image. Thus the green comes back in from the areas where the alpha was set to zero (or near zero) with out premultiplying the image.
    Anyone else notice this? I presume it’s a bug in FCP, yes? As a developer I’m curious as to what you guys do if you want to follow the chromakey process with a large blur (or other filter) that needs a premultiplied image as input. Do you use a premult filter, either within FCP or available from someone else?
    Pete
    RE:Vision Effects, Inc.
    Pierre Jasmin replied 17 years, 6 months ago 4 Members · 3 Replies
  • Ben Holmes
    February 10, 2009 at 11:05 pm
    Pete
    Interesting point, and one of the reasons why – when I need proper chromakey – I reach for After Effects.
    I suspect the issue you refer to could be resolved by nesting the clip before blurring it – have you tried that? I think the ‘premult’ issue is a fundemental limitation in the way FCP deals with multiple effect.
    I’ve not tried it, but suspect the premultiplied options in most Sapphire effects could cure this – have you tried this approach?
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • John Fishback
    February 13, 2009 at 4:06 pm
    Keylight (available on AfterFX for a while) is now available as a plugin for FCP. https://www.thefoundry.co.uk/pkg_overview.aspx?ui=76B1D869-EA48-4D89-8F13-FDE18802BCF8
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Pierre Jasmin
    February 13, 2009 at 5:47 pm
    Some compositing systems (AE, toxik, combustion, flame) are internally straight while others (Shake, Fusion, Nuke like FCP) are internally premultiplied by the alpha. None is right or better, you just have to be consistent, that is, as an operator/filter on the pixels you either expect one or the other. Much like for image IO, you usually set an incoming image sequence to the proper host basis if different (i.e. a premultiply or unmultiply button). If you select the wrong basis, then later in your project you will have issues.
    Of course what follows (LONG) only apply if the Alpha is not full-on.
    All this means is a semi-transparent pink tuna like color is as R,G,B,A
    not-premultiplied: 1,0.8,0.6,0.5
    pre-multiplied: 0.5,0.4,0.3,0.5
    The not-premulted application (eg AE) will do a premult prior to display result (as part of the display transform itself). The already premulted one will just draw RGB since A is supposed to be already applied to the color values (or composite it on a checkerboard background). It’s the same color (but not the same numbers) and in floating point a lossless operation to convert one to the other back and forth.
    Certain operations you want to do in one basis and others in the other basis, which assumes you know you are in a particular compositing basis, which is I think what Pete is complaining about, some FCP tools are apparently not premulted and another operator does not know that (as FxPlugs plugins we are told to expect premultiplied images).
    For example gamma conversion and most colorspace type work as well as a sequence of alpha channel manipulation, you probably want to do in so-called straight space,
    while most processing that composite / adds / average pixels you probably typically want to do in premult space.
    For the particular case of keying, it’s not unseen in premulted system to have the option not to premult the result out so one can continue manipulating the colors and alpha with a tool after it — prior to applying the alpha premultiplication necessary for the color to make sense at the end. In systems that allow that, then the user is expected to apply a separate premult filter after that (or post-multiply) before a compositing operation (where the two inputs/layers are merged).
    Now understandly FCP tries to maintain that workflow complexity out of your sight as it does not claim to be an effects system and Apple leaves that sort of process more exposed to EG Shake users… However there is certainly a bug in FCP keying tools if you can’t apply a chromakey followed by a gaussian blur without getting back background pixels your prior key is supposed to have removed. Of course if one removes complexity and does not provide workarounds then the user response is simply, well I’ll do that work in AE…
    It would appear that this could maybe just be an internal compositing state tag (premulted, unmulted) issue or something like that not handled prior to passing back the image(s) to the next operator/filter.
    I say that not knowing the code from the other side but recognizing that bug when I see it as is common to do such mistake when you have image processing libraries that have to run on either basis as plugin developers for multiple host applications must do. I imagine FCP has to do some minimal book keeping of that nature since for example an FxPlug expects premulted images and an AE plugins straight pixels… to say, since the bug is seen with many FCP video filters, the bug might be at another level of the system where compositing state is handled / managed ?
    Bug has been filed.
    Pierre
    http://www.revisionfx.com
