Chroma Keyer Trick
Posted by Joao Souza on January 6, 2014 at 3:32 pmFirst of all happy new year guys!
Some time ago I watched a tutorial about chroma keyer and it showed a trick using a color correction plugin I guess to make ONLY green color stronger, this way chroma keyer would work better, I even used it in one of my videos.
Now I don’t remember how to do that and i can’t find that video.
Do you guys know how to do it?
Thanks.We have so much time and so little to do! / Willy Wonka
Tom Edwards replied 10 years, 7 months ago 8 Members · 29 Replies -
John Rofrano
January 6, 2014 at 3:40 pm[Joao Souza] “Some time ago I watched a tutorial about chroma keyer and it showed a trick using a color correction plugin I guess to make ONLY green color stronger, this way chroma keyer would work better, I even used it in one of my videos.”
Color Corrector (Secondary) is what you’re looking for. It will allow you to target just one color (in your case the greens) and make them brighter/smoother.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Joao Souza
January 6, 2014 at 3:53 pmThanks Jon but even targeting only green still it changes the whole video cause there are greens everywhere.
In that video I remember he chose green and ONLY green was affected, I remember that was a button in that plugin that made it work like not affecting the whole video, damn if I could only remember that button name.
No matter how I pumped green saturation, it affected only green in green screen(background) and not green in the rest of the video(people, things etc).We have so much time and so little to do! / Willy Wonka
Roger Bansemer
January 6, 2014 at 4:28 pmThis video by Graham may be what you’re looking for.
https://reels.creativecow.net/film/grazie-2colour-and-black-and-white-and-grey-background
Roger Bansemer – PaintingAndTravel.com
John Rofrano
January 6, 2014 at 6:31 pm[Joao Souza] “…even targeting only green still it changes the whole video cause there are greens everywhere.”
If you have a green screen shot and you also have green in your video… you have a much bigger problem. The whole idea of using a green screen is to not use green anywhere else in your video except the screen. You could use the Mask tool in Pan/Crop to create a garbage matte so that other parts of the video are not affected but anything that is green in front of the green screen is going to be a problem.
~jr
John Rofrano
January 6, 2014 at 6:32 pmYea, Graham’s tutorial will show you how to fine tune the secondary color corrector. Good tutorial.
~jr
Joao Souza
January 6, 2014 at 6:36 pmThere’s no green besides in green screen however when you select that green and pump saturation, our faces have yellow so they’re affected too, you can see skin color has more green.
Graham Bernard
January 6, 2014 at 6:42 pmJoao, post a still here and what you want to have happen. What version of Vegas are you using? If you like what I come back with I will post the VEG.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Joao Souza
January 6, 2014 at 6:51 pmThanks but there’s no need of that, I just want to make green screen looks greener without affect the rest of the video, I select green screen green but when I pump saturation, it affects the whole video, I can tell it added green even to white parts so it’s not affecting only that green I selected but acting just like a color button to the entire video.
Graham Bernard
January 6, 2014 at 7:12 pmFrom your replies, I disagree.
Cheers
Grazie
Joao Souza
January 6, 2014 at 7:35 pmDisagree to what?
