Activity Forums VEGAS Pro Chroma Keyer Problem
  • Chroma Keyer Problem
    Posted by Justin Armstrong on June 12, 2013 at 10:00 pm
    I was using Chroma Keyer in SV12 but it has recently stopped working and i’m not sure what the problem is.
    I can select the Chroma Keyer effect and use the dropper to select the colour on the image but his is as far as I can go now… I can adjust both thresholds but the image does not change, if I select Mask only the image still does not change and Mask doesn’t work even though it is ticked.
    Any help would be appreciated.
    I should add that ive uninstalled and tried reinstalling the program and also reset all defaults but none of this has worked.
    Steve Rhoden replied 13 years, 1 month ago 2 Members · 3 Replies
