Activity › Forums › Boris FX Particle Illusion › Chroma Key
Chroma Key
Posted by Medion on September 14, 2005 at 7:26 pmWith Which Program did you the Green screen background
(Elvis Deane)Like the tutorial:Distintigrating People?Elvis Deane replied 21 years ago 3 Members · 2 Replies -
Mandyyjobs
September 14, 2005 at 9:11 pmI did mine in Vegas, but Premiere (most high end NLE) has the capability and so does After Effects.
Elvis Deane
September 14, 2005 at 9:42 pmI used Keylight in After Effects 6.5, but any program that can pull a key and then export the shot with an alpha channel can do the trick. Just make sure when you’re exporting the background that you make sure to save it with an alpha channel (in AE for example, you have to set RGB+Alpha in the Output Module, otherwise you just get the RGB with no alpha)
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
