  • Posted by Roger Burge on December 15, 2009 at 5:28 pm
    Hi I am trying to use green screen for the first time. I am applying filters in FCP. I have applied the chroma key filter, feather, matte choker etc. etc. The result looks good well quite good but the video now needs to be rendered. When I render I get huge pink glows and all sorts of disgusting effect surrounding and over my foreground talent. Any suggestions please or different software to achieve a good effect? thanks,
    Roger Burge The Video Works
    David Bogie replied 16 years, 8 months ago 4 Members · 5 Replies
  • Fred Miller
    December 15, 2009 at 7:29 pm
    How bout a little more info. What’s your footage shot on? What codec are you using?
    If your subject isn’t moving around to too much. The first thing I would do is put a garbage matte around it so I can tweak my key for a much smaller area. That may help you out.
    FCP Studio 2
    Dual 3Gg Quad Core
    4Gg RAM
    KONA 2
    OS 10.5.8
  • David Bogie
    December 15, 2009 at 7:30 pm
    Enlighten us first, what format were you shooting, which of the many chromakeyers in the studio are you using and what codec are you rendering to?
    bogiesan
  • Mark Suszko
    December 15, 2009 at 7:48 pm
    The “pink glow” may be from turning up the magenta spill killer/mate choker setting too high.
  • Roger Burge
    December 16, 2009 at 1:08 pm
    Hi David, I am shooting on a Sony XDCam EX1 1080p 25 fps. 422 codec
    Roger
  • David Bogie
    December 16, 2009 at 4:20 pm
    So you want to tanscode that to something non-GOP first?
    Szusko’s probably correct about the spill suppressor.
    You can research chromakey here and on the Net for many hours. it’s all been done and it’s all been fixed. Most fixes involve applying multiple keyers or masking to multiple stacked copies fo the same layer.
    bogiesan
