Activity Forums Apple Final Cut Pro Legacy Chroma, Brightness Shift when I press play
  • Chroma, Brightness Shift when I press play
    Posted by Don Ortega on February 6, 2006 at 7:41 pm
    I am using FCP 5.0.4 on a Dual 2.7 G5 hooked up to an X-Raid. Every time I press play, the colors get more saturated and everything gets brighter in the canvas. I’ve had this problem before and don’t remember how I fixed it. I remember it being some kind of simple trick.
    Dan
    Don Ortega replied 20 years, 7 months ago 4 Members · 5 Replies
  • Todd Reid
    February 6, 2006 at 8:53 pm
    try taking your overlays off.
    (safe title, timecode & luma)
    Thought they might have fixed this “feature” by now.
  • Don Ortega
    February 6, 2006 at 9:26 pm
    I took off the overlays, (By Luma, do you mean Luma check?) It didn’t work. It’s really strange because I know I had this problem before, and I forget how i fixed it! All my stuff is updated too.
    Dan
  • Bret Williams
    February 6, 2006 at 9:50 pm
    Just sounds like you’re not rendered to me.
  • Arnie Schlissel
    February 6, 2006 at 10:07 pm
    In your sequence settings (apple-zero) make sure your video processing is set to YUV.
    Arnie
    https://www.arniepix.com
  • Don Ortega
    February 6, 2006 at 10:30 pm
    I am rendered, even the native video plays this way. I’m also in YUV 10 bit HD 1080p23.98. So there shouldn’t be any RGB
    Dan
