Activity Forums Apple Final Cut Pro Legacy Choppy AE footage in FCP
  • Choppy AE footage in FCP
    Posted by Nayim Saati on September 16, 2010 at 8:55 pm
    hey guys so ive been working on an edit in fcp 6.0.6 and once i was finished with the edit i was taking each shot into after effects cs3 and grading it and doing other effects to each shot there. The process was that i was exporting a quicktime reference movie of each shot and working with that in after effects and then exporting a quicktime movie of the same codec (xdcam ex 108030p)and puting it back into fcp . It plays fine in the standalone quicktime player but once in fcp it wont play smoothly at all… it shutters, stops, freezes on a frame and more… the specs are exactly the same as the sequence and the orig clips, so i cant figure it out… any help at all would be great..
    i apologize if this is a common issue but i couldn’t find anything in the forums..
    apple g5 dual 2.7
    6.5 ram
    fcp 6.0.6
    AE cs3
    Alan Okey replied 15 years, 11 months ago 2 Members · 1 Reply
  • Alan Okey
    September 16, 2010 at 11:51 pm
    Try re-rendering your clip in AE using ProRes 422 instead of XDCAM EX, and change the codec in your FCP sequence to ProRes 422 as well.
