Activity › Forums › Adobe Premiere Pro › choosing which sequence settings for multi format
  • Jeff Pulera
    October 13, 2014 at 6:11 pm
    Some of the available presets have the SAME specs, but different names (same preset is duplicated). This is just for user convenience.
    If all the source clips are 1080p30, then choose ANY preset with those specs, it should make no difference. For instance 1920×1080, 29.97fps, progressive (no fields), 1.0 Pixel Aspect.
    You can drag a clip from the bin onto the “New Item” icon at lower right of bin, next to Trash Can. This will select an appropriate sequence to match your source.
    Jeff Pulera
    Safe Harbor Computers
  • Vince Beeton
    October 14, 2014 at 6:12 pm
    Thanks, Jeff. Really useful to know.
    TV Director/DP/Brand Visualizer in Bay Area
    https://portfolio.vincebeeton.com
