Activity Forums Blackmagic Design Choosing the Card for Pro Environment
  • Choosing the Card for Pro Environment
    Posted by Rededitor on May 15, 2006 at 3:40 am
    Hi there
    I was just about to purchase the HD Pro 4;2:2 card, but it looks like it has been superceded by the HD Extreme card.
    My dilemma is as follows…
    I will be running a WINDOWS XP setup.
    I need to be able to downconvert HD timelines to Digital Betacam, AND I need Analogue Audio In and Out.
    The main reason I wish to do so, is that for SD TV commercials, I believe I can maintain better quality by post-producing the entire ad in HD, then downconverting to Digi at the end for station use.
    My basic questions before purchase are:
    1. I assume I can capture SD (DigiBeta) in a HD project and playback in real-time. Is that correct?
    2. Is all HD captured vision playable back in realtime, or does it have to be rendered before playback? (excluding effects of course)
    3. If I purchased the HD Pro 4:4:4 PCI-X card (with no analogue audio), and then used the Multibridge unit to give us analogue audio I/O,.. will I get a 1 frame delay of the audio.
    Hope you can help, as I can’t find specific answers to these questions in the specs.
    Cheers
    RED
    Rededitor replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
