Activity › Forums › Apple Final Cut Pro Legacy › Choosing setup
  • Posted by Walter Miale on January 4, 2010 at 10:55 pm
    I just upgraded to FCP 7. I’m working with dv sd material in projects with dv timelines and also in ProRes timelines. I want to convert any dv timelines to ProRes and have ProRes as the default for new timelines.
    I presume that in the Easy Setup window, for Formats I click “all formats” and for Use I pull down the Custom setup to Apple ProRes 422. However the Use pulldown menu does not have ProRes as an option.
    What’s wrong?
    In the meantime I presume that Timeline Settings overrides Easy Setup, yes?
    Thanks.
    Rafael Amador replied 16 years, 9 months ago 2 Members · 3 Replies
  • Rafael Amador
    January 5, 2010 at 12:56 am
    Duplicate any easy setup and modify it.
    Let it checked in the “Sequence Presets” and will be your default whenever you open a new Sequence.
    rafael
    http://www.nagavideo.com
  • Walter Miale
    January 5, 2010 at 1:28 am
    Oh I see there are a million setups in the Final Cut Pro Additional Easy Setups folder on the desktop. The Help menu seems to be telling me that if I want them I have to reinstall FCP.
    I presume I can just ignore the Easy setup feature and the project and its timelines will never know, yes?
    Thanks.
  • Rafael Amador
    January 5, 2010 at 3:28 am
    You don’t need to reinstall.
    Open in FC “Easy Setups” and you will find a kind of “Setups manager”.
    Select the one you want to be available in FC.
    Or you can just drag them from the “Additional Easy Setups folder ” to the FC “Custom Setting” folder.
    rafael
