Activity Forums Adobe Photoshop Choosing only effect layers?
  • Choosing only effect layers?
    Posted by Malikai666 on July 11, 2005 at 5:33 pm
    is there a way to make an effect on a layer its own layer? say if I had a glow that was on a layer and I only wanted the glow on a seperate layer?
    Jeff Cochran replied 21 years, 2 months ago 2 Members · 1 Reply
  • Jeff Cochran
    July 12, 2005 at 3:32 am
    I’m assuming you have and image and you’ve applied a layer effect – Glow- to it. Duplicate the layer, rasterize the layer (Do this by creating an empty layer and merge the two. Now you can make a selection out of the image and the glow – apple click (Mac) or Control click (PC) on the layer Icon. Now create another layer and fill the selection, you have a glow by itself.
    Another way to do this if your working with a very dark or black image is to apply a “Screen” transfer mode to the layer (Layer pallette, top left of the pallette, pull down menu with “Normal” in it. Often Times I will take my image, fill it with black, add a glow or some other filter and use a transfer mode to loose the image and keep the effect. Try some of the other transfer modes. You can create some awesome effects
    Good Luck
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
