Activity Forums AJA Video Systems choosing Kona card for multiple audio streams
  • choosing Kona card for multiple audio streams
    Posted by Anshul Doshi on December 8, 2006 at 9:34 pm
    Dear All
    Currently I am setting up a FCP setup for a client to edit a feature film.
    I have a client who is hooting on HDCAM and will have Beta rushes also of a feature film
    I am deciding the correct caputre card.
    Perfect solution if I had all money is Kona3 with the breakout box
    The main consideration in the selection is the following:
    a) He needs to capture 4 streams of audio and monitor 4 or more streams of audio
    Is this possible with the Kona LH with a breakout box?
    Thanks and Regards
    Anshul Doshi
    Walter Biscardi replied 19 years, 9 months ago 2 Members · 5 Replies
  • Walter Biscardi
    December 8, 2006 at 9:58 pm
    Yes, via SDI the Kona LH can capture 8 channels of audio. 2 channels of Analog Audio.
    If you’re setting up a new Mac Pro machine or a G5 Quad, you will require the Kona LHe model.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Anshul Doshi
    December 8, 2006 at 10:01 pm
    thanks walter
    actually i need to have 4 channels on the output to an audio mixer
    is this possible through any audio de-embedder as on output i need 4 seperate channels of audio to go to the mixer.
    thanks
    anshul
  • Walter Biscardi
    December 8, 2006 at 10:06 pm
    According to the specs it will output 2 channels of analog, but I know it can output 8 channels via SDI. Call AJA and they’ll definitely tell you how to set it up for the 4 channel output you need.
    But yes, this can be set up. We output 4 channels all the time from our Kona 3 for mastering via SDI direct to the decks.
  • Anshul Doshi
    December 8, 2006 at 10:10 pm
    do you have a number for kona that you can give me where we will get support
    sorry to hassle
    thanks
    anshul
  • Walter Biscardi
    December 8, 2006 at 10:25 pm
    aja.com
