Activity › Forums › Maxon Cinema 4D › Choosing encoding format that wont cause issues in later compression
  • Steve Bentley
    August 8, 2017 at 10:17 am
    As long as you are rendering in an uncompressed format (QT animation best, tiff pshop etc) then the kind of file you render to doesn’t matter. The image will be what it is.
    Going from 250mb down to 10 or less you will loose something but if you are only doing grays then you are ahead of the game. Is the compress for the web or are you just trying to reduce the size and the you will work with it as an element? Different output formats from a compressor can make a difference in quality vs mb. But as long as the input movie is clean then the format you render to doesn’t matter.
    Also don’t judge the movie by a still – if you judged netflix by a still you would never sign up. The motion of all the compression “noise” often blends together and you don’t really see it. After all few notice film grain and it can be horrible.
  • Jeremy Paul
    August 8, 2017 at 1:41 pm
    I am doing an app promo and I extensively use reflections coming on to the screen and off while the mobile phone rotates. The reflections are a big deal for this particular use case. I am currently just trying to reduce size, but at the end, web is where it will be used.
    Video directly out of the Cinema is perfect so I guess I will need to further play with handbrake settings. None have been okay so far.
  • Steve Bentley
    August 8, 2017 at 1:45 pm
    Ok. Its probably the high rate of change of the bright flashes. If you increase the number of keyframes per second that will help. A big change can’t be captured properly in between keyframes. But be aware more keyframes means higher mb.
