Activity › Forums › Lighting Design › Choice of greenscreen fabric: “Tempo” or “Poly Pro”
Posted by Michael Hurwicz on August 1, 2012 at 6:02 pmI am looking at getting a 15′ x 15′ Digi Green greenscreen from laraghouse.com. They have “Tempo” fabric and “Poly Pro” for the same price. Can anyone fill me in on the pros and cons of the two types of fabrics?
(Hope this is not too far off topic. If there’s a better forum for it, please let me know.)
MikeElaine Ewing replied 14 years ago 5 Members · 6 Replies -
Mark Suszko
August 2, 2012 at 7:38 pmI’d have to see a sample and read the specs. You want the one with the flattest matte finish, not at all reflective, and you want something that will stretch and reject wrinkles. Spandex is typical on the low end, and is okay I think if the weave is tight enough that light doesn’t shine thru it when stretched. Fire codes vary by state and city, but insurance typically would want you to have the material fireproofed. The kind I like feels and looks similar to automotive headliner material.
Check out Rosebrand in New York; they have sample cards with actual swatches available, and they will tell you what each bolt is made of and the fire resistance.
Michael Hurwicz
August 2, 2012 at 7:46 pmThanks, Mark.
I found this description of Poly Pro at Rosebrand:
“A new, inherently flame retardant matte fabric preferred by major movie studios, with a brushed finish – the latest in keying fabric …”
Michael Hurwicz
August 2, 2012 at 9:46 pmGot this info from laraghouse:
There’s really no plus or minus but here are some differences.
* Tempo is 5′ wide and poly Pro is 10′
* Poly Pro Is rated and certified FR (flame retardant) and Tempo is not
* Tempo is light weight but denser in size due to being a foam product
* Poly Pro is the same weight and feel as Commando and folds down a lot smaller. -
Bill Davis
August 5, 2012 at 3:21 amHere’s the deal.
Keyiing today isn’t like it used to be.
It used to be incredibly finicky and required huge amounts of precision top to bottom.
Today, the software is better, the digital video world captures and reproduces more consistent signals, and there we have more lighting options than ever before.
All of which means your chances of success are tremendously better now then they were even 5 years ago.
So don’t obsess and sweat it so much.
Thicker and foam backed, thinner and more storable, fabric, screen, foam – they ALL work just fine.
The things the screw keys up are the same things that always did. Not creating an even light field on the keying surface and not having enough budget to shoot or capture in a format with enough resolution so that the software can accurately tell where one object ends and the next begins.
And at this point in keying technology – fabric has VERY little to do with that.
So relax and flip a coin. If fabric A keys for you – so will B, C and D. Because everything else has improved to the point where the fabric typically just isn’t the critical factor any longer.
Have fun.
“Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
Elaine Ewing
August 9, 2012 at 5:32 pm
