Activity Forums Adobe Encore DVD Check project novice question
  • Check project novice question
    Posted by Bruce Stubblefield on October 16, 2010 at 4:36 pm
    Hello,
    On a Mac 8-core, running Encore CS4, I’m making a BluRay .iso, starting with a 10 Bit uncompressed 1920×1080 Quicktime of a 90-minute feature. Just a bare-bones screening copy; no menus, just “insert and play.” When I get to “build”, the check project shows “End action not set” and “Title remote not set.” Everything under “Menu” is gray, including “Set End Action.” I can’t find any information about these problems. Can anyone tell me how to fix them, or if I even need to?
    Second issue: When I try to burn the BluRay in Toast 10 on the same machine, working from the BDMV/Certificate folders that Encore made, I get the Toast error, “Couldn’t set up the track for writing.” Could this be from something I’m doing wrong in Encore, or should I be posting this under “Toast?”
    thanks
    Bruce S
    Bruce Stubblefield replied 15 years, 10 months ago 2 Members · 2 Replies
  • Daniel Ludwig
    October 17, 2010 at 9:51 am
    Hi Bruce,
    as you´are creating a BD that needs to play the film only (without menus) you can ignor these informations, and go to built straight away.
    according to your 2nd issue:
    you need to select video>BDMV-folder, then create a new disk and put the BDMV and certificates-folder that you previously has been creating on the right side.
    that should work.
    last toast-version is 10.0.8.
    cheers
    danny
  • Bruce Stubblefield
    October 17, 2010 at 8:19 pm
    Thanks! Much appreciated.
    Bruce S
