Activity Forums Square Box CatDV “Check Archive Status…” error
  • “Check Archive Status…” error
    Posted by Jeff Schaap on January 15, 2013 at 1:31 am
    Trying to use CatDV to request archive status of clips in CaDV…
    Whenever I select a file or group of files in CatDV and select Tools > Check Archive Status, in a window I get:
    Failed to check Cache-A archive status ([Ljava.lang.Object; cannot be cast to java.util.Map)
    And of course I have no idea what that means.
    This is CatDV9 Professional (Mac) with Cache-A (latest and greatest software on it I assume because Cache-A spent several days just recently working on it).
    Anyone have ideas on what the issue may be?
    Argh,
    Jeff Schaap
    Rolf Howarth replied 13 years, 7 months ago 3 Members · 3 Replies
  • Matthew Stamos
    January 15, 2013 at 4:13 pm
    Hey Jeff can you send screen shots and logs and this description to support@squarebox.com
  • Jeff Schaap
    January 16, 2013 at 7:08 pm
    Will do!
  • Rolf Howarth
    February 13, 2013 at 1:25 pm
    This is fixed in the forthcoming CatDV 10.0.2 update. Cache-A have made some improvements to the Check Archive Status API and you need the new CatDV update to make use of them.
