Activity Forums Apple Final Cut Pro Legacy Cheap (software) SD to HD conversion
  • Cheap (software) SD to HD conversion
    Posted by Jimmy joe Roche on June 29, 2010 at 3:26 pm
    Hello
    So I have a SD footage that I want to convert in the best possible way to 720 by 960. The footage is 4:3 but I want to stretch it to 16:9 ( it will actually be in the proper aspect ratio after being stretched). BUT
    I only have After Effects cs4 and cs5 and FCP suite 6 as resources. No hardware for this unfortunately. What is the best way to do this?
    thanks much
    jjr
    Harry Bromley-davenport replied 16 years, 2 months ago 7 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    June 29, 2010 at 4:57 pm
    Hi Jimmy,
    AE should be enough to do the job.
    I’m not sure if you can chose in AE the scaling filter, but have a look.
    Render in 16 or 32b.
    [jimmy joe roche] “No hardware for this unfortunately.”
    Being a non standard size, no sure if any hardware would do the job.
    Rafael
    http://www.nagavideo.com
  • Steve Eisen
    June 29, 2010 at 6:59 pm
    or Compressor
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Eric Pautsch
    June 30, 2010 at 2:44 am
    AVISnyth is what I would use….and its free!!
  • Bret Williams
    June 30, 2010 at 6:02 am
    If I understand him correctly, it’s anamorphic SD. He says it’ll be the right aspect after being stretched. 960×720 is also anamorphic but HD. It’s not non standard, it’s DVCProHD 720p. It’s even more anamorphic. But I think I’d go ahead and make it ProRes 1280×720
  • Rafael Amador
    June 30, 2010 at 9:14 am
    Jimmy’s post is very unclear.
    The only reason to go DVCProHD, is if you have to deliver in that format.
    Whatever the way, will need to crop the picture.
    rafael
  • Dennis Radeke
    June 30, 2010 at 10:41 am
    Adobe Media Encoder, Compressor, After Effects can all do the job. If you’re looking for DVCProHD (960×720), you can create a native P2 file structure using Adobe Media Encoder.
  • Harry Bromley-davenport
    July 1, 2010 at 6:05 am
    I suggest that you use MPEG Streamclip.
    It’s a very good little program from Apple and – it’s free.
    I have compared it to Compressor and to Red Giant thing and I think MPEG Streamclip is in fact better.
    We had a shot for a show for a major DVD release which, for various reasons, was shot in SD at night. It had to be uprezzed. It got through QC without their noticing at all. I admit that I did also use Neat Video on it, but give it a shot.
    Harry.
