  • Posted by Cuel on May 24, 2005 at 6:44 am
    Ok here is the deal, basicly I would like to apply a chat window in the lower left corner with a black background and opacity like 10%. I want to be able to add text there, when it should be applied, color and size and stuff you do with text.
    Does someone know a easy way to create this? Is it easier to create a plugin? I really need this to my movie, it is probably the last thing I need to know before finishing my movie. Please Help.
    Filip Vandueren replied 21 years, 3 months ago 4 Members · 4 Replies
  • Graham Quince
    May 24, 2005 at 7:49 am
    i presume you mean simulate a chat window in video right?
    if that’s the case, it’s really very easy. Create a black solid, and use a square mask to set the size and position to the where you want it. Open up the layer opacity, the ‘t’ key and set it to 10% or whatever.
    Now click on the test tool, and draw a box to match the size of your mask. you can now add type and the text will wrap itself within the confines of the text box.
    Graham
  • Seth Taylor
    May 24, 2005 at 3:49 pm
    Or, you could record your screen while you chat with someone, then import that to your movie.
  • Cuel
    May 24, 2005 at 4:05 pm
    Ok thanks. But I need to know how to make the text “move up” when new text pops up. So example
    _
    [bla]says: yo
    _
    i want it to move up when someeone writes back, like this
    _
    [bla]says: yo
    [ey]says: sup
    _
  • Filip Vandueren
    May 24, 2005 at 11:06 pm
    1. Create your text layer with all the lines in it
    2. Add an animator: Animate: Opacity. set opacity to 0, your text will disappear
    3. Twirl open “Range Selector” -> “Advanced” and set Units to “index” and Based On to “lines”
    4. Close the Advanced Twirl
    5. give the AnchorPoint this expression:
      leading = 50; // change this value to the leading of your textlayer
      animOffset = text.animator(1).selector(1).offset;
      [0,leading]*animOffset;
    6. Now animate the Offset-parameter of the Animation Range from 0 – # of lines
    The trick lies in animating with pauses and hold-keyframes, so it actually looks like someone is reading, then sending instead of just a stream.
