Activity › Forums › Adobe Premiere Pro › Character problem when using dynamic link AE
  • Character problem when using dynamic link AE
    Posted by Jeremy Scala on February 20, 2020 at 1:44 pm
    Hello,
    I’m using AE et Premiere 2020 and I’m having a weird glitch. I have a composition in AE with a little animation on a text from a preset I download on Motion Array. It’s working fine in AE. But when I’m importing my composition in Premiere, the characters changes randomly for one frame. I have no idea why. I already used this composition a number of times on other video without problem. I never changed it, but all the sudden it happened.
    If you have an idea, please share ☺ Thanks
    The preview in premiere:
    The preview in AE:
    Jeremy Scala replied 6 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • Todd Perchert
    February 20, 2020 at 5:17 pm
    Things you can try…
    Delete Render Files. Clear out your cache. Render from AE and import the render file.
  • Jeremy Scala
    February 21, 2020 at 8:44 am
    Thanks for your answer, but I can’t use a render because on another composition not showing in the screenshots, I need transparency over my video in Premiere.
    But I’ll try the two other things you suggest.
  • Jeremy Scala
    February 21, 2020 at 8:58 am
    Ahah I didn’t know I could clean the cache, weirdly it was set to only take 46go but it was 88Go on my poor 500Go ssd of my Macbook Pro. I’m happy I clean it for storage purpose, BUT it didn’t solve my initial issue.
    Here is two videos of the problem:
    https://youtu.be/nGTpCwaPHhU
    https://youtu.be/NABIjJVcSDA
  • Todd Perchert
    February 21, 2020 at 3:11 pm
    Try from AE, in Preferences, Media & Disk Cache – Clean Database and Cache.
  • Jeremy Scala
    February 27, 2020 at 3:18 pm
    Did not work either.
    So I did some research (quickly on google ????) about video with transparent background thinking that doesn’t exist, but it does. So I finally render my composition in AE that was working. It’s a workaround for now.
    Thanks for your help
  • Todd Perchert
    February 27, 2020 at 9:28 pm
    About the only other thing I could think of was maybe some strange thing happening with your video card. You could try turning off the GPU acceleration in preferences, putting it to Software Only to see if that does anything for you.
    TC
  • Jeremy Scala
    February 28, 2020 at 11:39 am
    Will try, thank you ☺
