Activity Forums Adobe After Effects Character Animation – Puppet Tool
  • Character Animation – Puppet Tool
    Posted by Simon Balch on December 17, 2009 at 5:18 pm
    Hi there. I’m animating a character using illustrator/ after effects. I have the character’s arm and a hand on two separate layers. With the hand parented to the arm layer. However, when i move the arm with the puppet tool, the hand does not follow. Is there any way to make the hand follow the arm, without having to animate the hand frame by frame, or is that just the way it is? Thanks.
    Pedro Deltell colomer replied 12 years, 5 months ago 3 Members · 2 Replies
  • David Johnson
    December 17, 2009 at 5:46 pm
    There may be a more complex scripting/expressions option, but is there a reason you can’t just have the arm and hand as one ‘layer’? It seems a hand will never naturally move too independently of an arm so, perhaps just precomp the arm and hand layers. If, for example, the hand needs to wave, there would probably still be some arm movement so perhaps a second instance of the hand layer might do for the rest of the motion that applies to only the hand. It seems the same rationale could also apply to any finger motion there may be.
    It’s hard for me to put my AE thought process into words so I hope that makes some kind of sense and is helpful.
  • Pedro Deltell colomer
    April 8, 2014 at 8:36 am
    See here:
    https://vimeo.com/11605429
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
