Activity › Forums › Apple Motion › Character Animation in Apple Motion
  • Character Animation in Apple Motion
    Posted by Utara Sone on June 29, 2013 at 11:31 am
    Is there a workflow in Motion 5 that can do animation in the way that the puppet tool in After Effects works?
    For example, the way Daniel Gies used After Effects to do this:
    https://www.youtube.com/watch?v=Ojv3XJBrXhs
    Or is After Effects the only software that can do this? Not counting using 3D animation software (like Maya used for “South Park”).
    This question has been asked before, but it has been a couple of years, and there’s a new Motion now.
    arigato!
    [Edit: For some reason, I originally posted the wrong link to the example I am referring to. It’s corrected now.]
    Utara Sone replied 13 years, 2 months ago 2 Members · 3 Replies
  • Utara Sone
    July 2, 2013 at 8:50 am
    Anyone, anyone?
    Bueller? Bueller?
    (^_^)
    I’m thinking there must be a way to rig a character in Motion 5 in some way, no? I just don’t yet understand it enough to know how to go about it. But perhaps the lack of info on doing such a think in Motion, compared to AE, should tell me something. Ne?
  • Stephen Smith
    July 2, 2013 at 2:50 pm
    First off. I have Motion 4, not 5 for reasons not worth getting into. Anyways, Yes you can animate characters and that tutorial doesn’t use the puppet tool. You don’t have adjustment layers and expressions but they aren’t needed. The key to character animations like I did for this Book Trailer is being able to parent items. For example, parent the hand to the arm so they both move together but you do the parent order so that if you rotate the hand it doesn’t effect the arm. Not sure if I’m making sense. Motion 5 has a parameter rig feature. I’m not sure but I thought that was supposed to be like parenting in After Effects. Hope this helps.
    Stephen Smith – Follow me on Behance
    Utah Video Productions
    Check out my Vimeo page
  • Utara Sone
    July 8, 2013 at 6:52 am
    Thank you, Stephen, for your help. I will look more into that. I’m just beginning to learn Motion, as I can not afford After Effects and don’t want to get it through “other” means. I realize that the two pieces of software aren’t competing in everything the way, say, Maya does with Cinema 4D, but Motion is a start for me.
    Thank you again for responding to my post. Your video shows me that I can do some of things I want to accomplish in Motion.
    (^_^)
