Activity Forums Adobe Encore DVD Chapter Playlist Questions
  • Chapter Playlist Questions
    Posted by Tylerc on January 11, 2007 at 6:17 pm
    I’m not really sure if this has been answered or not. I’m fairly new to Encore and was wondering if it is possible to pull this off.
    Let’s say I have 13 video clips. I would like the user to be able to select any number of these clips from a list and click play to watch them one after the other like a playlist. This playlist would loop until the menu button was pressed and they could choose different clips and the process would start over.
    Thanks in advance for any help or info you can provide.
    Robert Hallion replied 19 years, 7 months ago 2 Members · 1 Reply
  • Robert Hallion
    January 12, 2007 at 6:35 pm
    The easiest way to do it would be to have 1 timeline with 13 chapter points on it (1-13). Create a menu that will have 13 buttons on it. Map each button to the correct chapter point on the timeline. Make sure you set the timeline to loop and all that. So, if the user clicks 7 it will go to chapter 7 on the timeline then continue to play.
    Hope that helps.
