Activity Forums Adobe After Effects Channel Combiner “cutoffs” my effect brightness
  • Channel Combiner “cutoffs” my effect brightness
    Posted by Lord Scales on May 16, 2007 at 1:05 am
    I am applying Channel Combiner to create an Alpha Channel in a CC Light Rays. I know I can set my Black Solid mode to Screen, but the result won’t be the same.
    The problem is that if I apply Channel Combiner to it (selecing lightness and turning to Alpha) the bright of the CC LR diminish a lot. I tried other combinations like Max RGB to Alpha, but it was not perfect. Max RGB to Alpha Only doesn’t allow my CC Light Rays to be blue.
    I need help now. Is there any other effect to turn Lightness into Alpha with no “cutoof”?
    Thanks;
    Lord Scales
    Lord Scales replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
