Activity Forums Apple Final Cut Pro Legacy Channel 3 and 4 on capture in FCP 5
  • Channel 3 and 4 on capture in FCP 5
    Posted by Virge Castillo on September 13, 2005 at 8:54 pm
    When I capture in FCP 5 it is now capturing four channels of audio for each clip. I’ve looked to no avail for somewhere to set it so that it only captures CH. 1 and 2. Can someone point me in the right direction?
    Jerry Hofmann replied 20 years, 12 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 14, 2005 at 2:01 pm
    If we are talking DV, look in the capture presets you are using… in the preset editor window you open by clicking on this preset in the A/V settings, you can select which and how many tracks are being captured.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
