Activity › Forums › Adobe After Effects › Changing Timeline bars of layers when time is extended in a compositon
  • Changing Timeline bars of layers when time is extended in a compositon
    Posted by Ugo Amadi on September 2, 2011 at 4:58 pm
    Hello all.
    I wonder if there’re some hot keys on the keyboard that can be used to extend the timeline bars of a layer or layers once you extend the time on the timeline from the the composition settings, let’s say from 2s to 10s.
    I noticed that After extending my composition time from the composition settings from my initial 2s to 10s, the bars on the timeline still only remained from 0s to 2s, but didn’t extend all the way to the new 10s time.
    I wonder if someone can help me with the hot keys to make this adjustments.
    Thanks.
    Ugo.
    Ugo Amadi replied 15 years ago 2 Members · 2 Replies
  • Steve Blacker
    September 2, 2011 at 5:57 pm
    Select the layer, put the timeline indicator where you want the start of the layer and then press “Alt” + [ to bring the start of the layer to the current time indicator, or Alt + ] to extend the end of the layer to the current time indicator.
    It’s only work if you’d rather be doing something else…
  • Ugo Amadi
    September 6, 2011 at 4:46 pm
    Works like a charm.
    Thnx Steve.
