Activity › Forums › Adobe After Effects › changing the transform properties on a layer across multiple compositions
  • changing the transform properties on a layer across multiple compositions
    Posted by Alistair Mcclymont on March 4, 2017 at 11:33 am
    I’ve got over a hundred compositions in a folder – each with one layer with a scaled video.
    I’ve need to duplicate every one of those compositions and change the scale transform property of that layer in every single composition.
    Its a bit time consuming – any tips or scripts that may help with this?
    Alistair Mcclymont replied 9 years, 7 months ago 2 Members · 4 Replies
  • Mike Sevigny
    March 4, 2017 at 3:32 pm
    Here’s a script that will duplicate the compositions in the folder, resize the layers to 150% and place the new comps in a new folder. Check the ‘settings’ at the top of the code to set your custom folder name and custom size.
    // Settings
    folderName = 'myFolder'; // Folder with |Original Compositions
    customScale = [150, 150]; // Custom Scale
    // Find target Compositions
    targetComps = new Array();
    for (e= 1;e<= app.project.numItems; e++) {
    if (app.project.item(e) instanceof CompItem){
    if (app.project.item(e).parentFolder.name = folderName) {
    targetComps[targetComps.length] = app.project.item(e);
    // Duplicate the Compositions
    newFolder = app.project.items.addFolder('dupComps');
    for (a=0;a<=targetComps.length-1;a++){
    thisCompDup = targetComps[a].duplicate();
    thisCompDup.name = targetComps[a].name + '-dup';
    thisCompDup.parentFolder = newFolder;
    thisCompDup.layer(1).transform.scale.setValue(customScale);
    Hope this helps,
    Mike Sevigny
    https://www.torusmedialabs.com
  • Alistair Mcclymont
    March 5, 2017 at 12:54 am
    i’m running it now and it may need some work – but thanks so much for providing the script. I program elsewhere, but am new to after effects scripting – obviously going to be fun.
    i’m getting some functionality from the script – but i get this error:
    unable to execute script at line 19. Function targetComps[a].duplicate is undefined
    the script is making a folder ‘dupComps’ – its also making many copies of the target folder – these seem to contain slightly random comps, many of which weren’t in the target comp
    i made a new project with some simple comps with a solid in each – 3 were in a folder and 3 loose in the project. The script ran, but put every comp in the new folder
  • Mike Sevigny
    March 5, 2017 at 4:56 pm
    You’re right, for some reason it’s not recognizing the Item’s parentFolder. I changed a few things around so that it uses the folder you’ve selected intead of trying to find it by name. I commented the script to give you an idea of what’s going on at each step.
    Give this a try:
    sourceFolder = app.project.activeItem; // Collect the currently selected Folder
    if (sourceFolder instanceof FolderItem) { // If the selected Item is a Folder
    targetComps = new Array(); // Create blank Array to store the Compositions
    for (e= 1;e<=sourceFolder.numItems; e++) { // Cycle through the Folder Items
    if (sourceFolder.item(e) instanceof CompItem){ // If the Folder Item is a Composition
    targetComps[targetComps.length] = sourceFolder.item(e); // Collect the Item into the Array
    newFolder = app.project.items.addFolder('dupComps'); // Create a new Folder for the duplicate comps
    for (a=0;a<=targetComps.length-1;a++){ // Cycle through the collected Project Items
    thisCompDup = targetComps[a].duplicate(); // Duplicate this Composition
    thisCompDup.name = targetComps[a].name + '-dup'; // Rename the duplicate
    thisCompDup.parentFolder = newFolder; // Place the duplicate composition in the new Folder
    thisCompDup.layer(1).transform.scale.setValue(customScale); // Change the scale of the first layer in the duplicate composition
    }else{ // If the selected Item is not a Folder, throw error.
    alert('You must select a folder to be processed')
    Before running it:
    After running it:
    Hope this helps,
    Mike Sevigny
    March 5, 2017 at 4:57 pm
    great cheers – i’ll give it a whirl asap
