Activity Forums Maxon Cinema 4D Changing the radius of a polygon cylinder?
  • Changing the radius of a polygon cylinder?
    Posted by Kyle Sowden on August 11, 2011 at 11:13 pm
    I made a cylinder, and you can change the radius simply then.
    Infact, i’m making a tin can. and it went perfectly until I decided to change the label on it. Now the label doesn’t fit properly and I need to change the radius, how do I do it now?
    Kyle Sowden replied 15 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 12, 2011 at 12:38 pm
    Not sure if you want to chane the shape of the cylinder or the projection of the label. You can do the latter by selecting the texture tax and adjusting the length U/V settings.
  • Kyle Sowden
    August 12, 2011 at 9:31 pm
    I’m trying to keep the height of the entire cylinder but make it’s width smaller
