Activity Forums Adobe After Effects changing the mask shape
  • changing the mask shape
    Posted by Delorian on June 22, 2005 at 10:01 pm
    Hi everybody,
    i just started to AE and would apreciate a lot if you would help me out with this one.
    ok here is the situation :
    I have 2 layers. One of them is made with fractial noise. it is some kind of moving lava which have a random motion inside.
    and other one is a white solid layer with a mask.
    the duration of the clip is 5 sec.
    I want this mask to change its shape randomly with in 5 sec. as if the lava behind burns out the paper(the white solid layer) at the back and spreads on it.
    I have seen the tutorial with the news paper burning but thats not what I want
    i need to control the shape of the mask with in a certain period of time if its possible.
    any suggestions ? or alternatives ?
    thanks.
    Kemal.
    Steve Roberts replied 21 years, 2 months ago 2 Members · 1 Reply
  • Steve Roberts
    June 23, 2005 at 5:06 am
    Animate the mask shape parameter using keyframes, as outlined in the manual. You have to do it by hand — it won’t animate its shape randomly automatically.
    Another option is to use the gradient wipe transition effect. It requires footage or a comp layer to be used as the gradient map. The transition is applied to a layer using the grayscale values of the map to make the transition. A linear gradient, used as a map, would make a linear wipe, since the grayscale values go from black to white in a linear fashion. Try it with a fractal.
    But if your map is an effected layer, make sure you precomp that layer or render it. AE uses a map layer in a comp before any effects have been applied to it in that comp — that’s why you have to render the map layer or precomp it.
    Hope that helps,
    Steve
