Activity Forums Apple Final Cut Pro changing the length of a still or movie clip with transitions at both ends.
  • changing the length of a still or movie clip with transitions at both ends.
    Posted by Anita Sancha on May 18, 2014 at 9:04 am
    Hi all..
    How do I change the length of a still or movie clip with transitions at both ends without having to delete the transition at one end to grabb the handle and the reducing the clip …. this is not retiming as a still can’t be retimed using retime … just changing the duration because i can access the retime using command and R.
    Cheers
    Thanks for all your help
    Anita Sancha.
    http://www.anitasancha.co.uk
    Anita Sancha replied 12 years, 3 months ago 3 Members · 4 Replies
  • Trust Helpful
    May 18, 2014 at 9:49 am
    Hello Anita Sancha
    Grab in the middle of the transition on the two arrows pointing at each other at the end of the clip and drag the clip as long as you want it to be.
    Trust
  • Bret Williams
    May 18, 2014 at 2:23 pm
    Ctrl D, then type in duration
  • Bret Williams
    May 18, 2014 at 2:26 pm
    FWIW you don’t have to delete the transition to drag out the duration either. You have to zoom in close enough, but there’s a grab handle at the upper portion of the dissolve that drags out the clip, not the transition.
  • Anita Sancha
    May 18, 2014 at 4:41 pm
    Thanks… just what I needed. x
    Anita Sancha.
