Activity Forums Apple Final Cut Pro Legacy Changing the inpoint on multiple clips, or create handles on multiple clips.
  • Changing the inpoint on multiple clips, or create handles on multiple clips.
    Posted by Kenny Holl on September 29, 2012 at 2:24 pm
    I videotaped a party. I captured the footage and it separated into 81 clips. Now I’d love to be able to put in dissolves between all of them. I know I can put them in the timeline, select all of them and change the duration by a certain number of frames (say -15 frames), but that only affects the outpoint. Is there a way to do all 81 inpoints at the same time.
    i.e. is there any way to create handles on multiple clips at the same time?
    Kenny Holl replied 13 years, 7 months ago 1 Member · 1 Reply
  • Kenny Holl
    February 15, 2013 at 5:52 pm
    New party, same problem. Only now I have over 200 clips. I’d love to trim them all at once to create handles on all, but I don’t know how. Here’s the easiest method I know of so far. I put all the clips in my timeline and highlight all of them. Then I go to duration and reduce the duration by, say 8 frames, which trims the outpoint on all the clips. Then I put them back into a new bin, and I manually add “+8” to each clip’s input.
    Is there a better way????
