Activity Forums Maxon Cinema 4D Changing the falloff of an Emitter
  • Jim Scott
    September 12, 2017 at 5:33 pm
    What particle system are you using? I don’t know of any way to use different shapes as emitters in C4D’s system, but if you’re using X-Particles you can use any object or spline as an emitter by setting Emitter Shape to “Object” and placing an object or spline into the Object window.
  • Brian Jones
    September 12, 2017 at 6:30 pm
    yeah, no way to do it with original particles but TP can emit from a spline (or other objects) – there is a TP Spline Emitter preset in the content Browser… (or as Jim says XParticles)
  • Bashar Hassouneh
    September 12, 2017 at 7:43 pm
    Yep that’s it, I’m buying that X particles plugin now.
    thanks, guys.
