Activity Forums Avid Media Composer changing text size all over
  • changing text size all over
    Posted by Lizkateland on February 5, 2008 at 3:29 pm
    except for changing the screen resolution, is there any way to increase the text size within the bins, effect editor etc? its so tiny! we changed the screen resolution to give me more”real estate” but now all the print is so small – just wondering
    Jon Zanone replied 18 years, 7 months ago 3 Members · 2 Replies
  • Brian Thomas
    February 5, 2008 at 3:39 pm
    When you are in Avid Title Tool, there is a small white box on the bottom of the window in which you can type in the number of the font size…you should always make the text as large as title safety will allow and then make it smaller in Avid using the 3D warp tool…good luck
    Avid Editor
    New York City
  • Jon Zanone
    February 6, 2008 at 12:29 pm
    If you mean the text on the actual windows, go to (I think, I’m not in front of an Avid right now…) Edit/font. Somewhere in there is a way to change the font and size only within Avid. As a more global way to change, right click on the desktop, select settings and go to (I think – I’m on Vista at home and it’s totally different than XP) the settings tab. Somewhere there is the setting to make the window fonts larger.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
