Activity › Forums › Adobe Illustrator › Changing text perspective
  • Vincent Rosati
    September 8, 2015 at 1:05 am
    Try Effect > 3D > Rotate.
    After it’s created you can access the settings the Appearance palette.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
