Activity Forums Adobe After Effects Expressions Changing text layers.
  • Changing text layers.
    Posted by Erick Pinell on May 18, 2009 at 5:39 pm
    I have a project with 2 text layers. Is there anyway I can swap out the text on those layers without opening the application? Can I edit the xml version of the project file?
    I’ve looked at the xml version in CS4 but cannot locate where to swap out the text.
    Any help is greatly appreciated.
    Erick.
    Todd Kopriva replied 17 years, 3 months ago 2 Members · 3 Replies
  • Todd Kopriva
    May 18, 2009 at 6:18 pm
    The contents of the Source Text property are not saved as human-readable/human-editable strings in the XML project file format.
    There are some scripts that people have written to pull in text from external files. I’ve not used them enough to settle on a favorite, so someone else should chime in to say if they’ve like any of these scripts.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Erick Pinell
    May 18, 2009 at 6:51 pm
    Todd,
    Thanks for the tip on the XML. I’ll stop looking there.
    If you have the links to the scripts you mentioned, or can point me in the right direction, I’d love to take a look at them.
    Erick.
  • Todd Kopriva
    May 19, 2009 at 12:37 am
    OK. I’m not necessarily endorsing any of these. These are just ones that I’ve tried at some time in the past and found to at some time be useful.
    find and replace text from files
    getting Source Text out of a text file
