Activity Forums Adobe After Effects Changing Temporal value – 29.97 – 25fps?
  • Changing Temporal value – 29.97 – 25fps?
    Posted by Kevin Watkins on September 10, 2009 at 5:38 pm
    This seems far too simple to be a realistic solution:
    I have a 720 29.97fps comp that has type etc over footage (animation codec) – never longer than about 15 seconds, talking head. The client requested an editable file for use overseas by their affiliates. They want the same 1280×720 frame size but at the PAL 25fps frame rate. I simply changed the frame rate in the Comp settings and rendered out a file. Which seems to be ok…(The original files appear to be slightly out of sync anyway due to a boom mic that seemed to be pretty far away, so its incredibly hard to tell with the 25fps files…)
    Will this really work? Should I not have the footage converted to 25fps first and then re-build these files?
    Kevin Watkins.
    Mac Pro using AE CS4
    Kevin Watkins replied 17 years ago 30,162 Members · 1 Reply
  • Kevin Watkins
    September 10, 2009 at 8:50 pm
    Thanks Dave. I was planning on sending it out to have the frame rate converted via an Alchemist system. Tried this as a test and the QT file is difficult to gauge, as I mentioned.
    If its too good to be true…
