Changing stretched frame resolution change
Hey my friend is using final cut pro however the camera shes using will only export footage as widescreen and “pillarbox” it causing select frames to appear stretched and therefore blurred.
As i have never used final cut pro if the footage was exported as widescreen would it not be “letterboxed” or is that the same thing?? and is there a way that the resolution of these stretched frames can be changed to suit the other frames and therefore cut out the blurring??
Any help would be greatly appreciated
thanks
Michael
