Activity Forums Adobe Illustrator Changing size of logo created with brush shapes
  • Changing size of logo created with brush shapes
    Posted by Rose Falgout on June 7, 2012 at 10:59 pm
    Hello,
    I am new to illustrator…
    I created a logo with brush shapes and when I try to resize larger or smaller the logo doesn’t look like the original design.
    I have grouped the shapes together but it still changes shapes.
    Thank you very much…
    RF
    Nicole Nel replied 14 years, 1 month ago 3 Members · 2 Replies
  • Tylor Larson
    July 4, 2012 at 5:00 pm
    to solve this issue you need to double click the SCALE tool… this should bring up a dialog box for the scale tool… at the bottom of that box there is a check mark for scale stroke and effects.. with this on it will scale the brush stroke when you scale your object.
    TY
  • Nicole Nel
    July 24, 2012 at 6:29 pm
    Convert the paths to outlines. Select and then go to: Object – Path – Outline Stroke.
    If that doesn’t do the trick then go to (with the object selected): Object – Expand.
