Activity › Forums › Apple Motion › Changing size after the pilot sketch
  • Changing size after the pilot sketch
    Posted by Alexandre Hotton on May 27, 2009 at 12:36 pm
    Hello
    I’m on a Begining credits project. I have to deviver in 1920/1080.
    It’s Heavy so I would like to work in 900/500 from my 3D app and when I’m happy, then recalculate in full HD.
    I Know I can relink, but how could I do to get no problem. I use some particles.
    Thank a lot
    Alex
    Stephen Smith replied 17 years, 4 months ago 3 Members · 3 Replies
  • David Bogie
    May 28, 2009 at 5:17 pm
    Dangerously fraught with gotchas and unpredictable results that will clandestine and esoteric errors.
    Umm, that won’t tranlsate well. I shall rephrase:
    Do not try to convert the smaller project to a larger project.
    Experiment in the smaller size to learn how to create your effects. Use this as your skethboard, your draft editor, your roughcut assembly.
    figure out what you can do to streamline and simplify such as render certain layers as complete movies.
    But produce only in the larger size.
    bogiesan
  • Alexandre Hotton
    May 28, 2009 at 7:19 pm
    thanks
    alex
  • Stephen Smith
    June 2, 2009 at 6:59 pm
    I agree with bogiesan, I can see a lot of things going wrong. Keep in mind you can always work in the “Draft” render quality. Best of luck.
    Lone Peak Productions
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
