Activity › Forums › Adobe After Effects › changing shortcut for camera view?
Posted by Rob Pilichowski on December 15, 2008 at 8:00 pmi’ve tried to look this up online and both recommendations of using “assign shortcut to Active Camera” and holding shift while selecting an F key haven’t worked. I’m on a mac so whenever i hit the F9-F11 keys it affects the Dock and finder. Basically, i just want to reasign my shortcut keys for the different camera views, any suggestions?
Jan Sherlink replied 17 years, 9 months ago 2 Members · 7 Replies -
Jan Sherlink
December 15, 2008 at 10:27 pmYou can edit you shortcut preferences;
they are located in:
User/Library/Preferences/Adobe/AfterEffects/8.0/
and called
Adobe After Effects 8.0 Shortcuts.txtmake a backup of the file and change the settings you want;
“SwitchTo3DViewFirst” = “(F10)”
“SwitchTo3DViewB” = “(F11)”
“SwitchTo3DViewC” = “(F12)”cya,
Jan
Rob Pilichowski
December 16, 2008 at 8:59 pmis there not an easier way to do this directly through AE?
i’m still not getting the results i’m looking for. I just want to assign shortcuts
to Active Camera, left and top views….any suggestions?
i got F1 to do a top view, F2 does a custom view (which i don’t want) and F3 has
no effect on the camera at all, even though i switched it in the shortcut preferences… -
Jan Sherlink
December 16, 2008 at 9:27 pmThe Key-bindings only can be set in the txt-file,
I’ve heard they’ll change it in CS17 😉AE only allows 3 camera shortcuts to 3 keys
Don’t forget to use the ‘ Assign Shortcut to “X camera” ‘
So if you’re in Front view and use the “Assign to”, the camera will be mapped to the selected function key.cya,
Jan
Rob Pilichowski
December 16, 2008 at 9:33 pmok, i got F1 and F2 keys to be active and top camera views.
i’m trying to assign F3 to be my left camera but its not happening, any thoughts? -
Jan Sherlink
December 16, 2008 at 9:44 pmMake sure there’s no other binding to F3
in my txt file I can find : “ToggleEffectControls” = “(Ctrl+Shift+T)(F3)”
so you’ll need to delete the F3 therecya,
Jan
Jan Sherlink
December 24, 2008 at 3:21 pmWhen you look for something…
the first thing you’ll find is something else …made me think about this topic,
there seems to be a script to bind shortcuts inside CS3 !
check it out:
https://www.aenhancers.com/viewtopic.php?f=3&t=969cya,
Jan
