Activity Forums Adobe After Effects Changing shape mask
  • Changing shape mask
    Posted by Jim Bachalo on May 17, 2013 at 2:52 am
    Need some expert advice as to the best method of approaching this masking problem where the mask changes shape as the shot changes perspective.
    In the following low res render I need to separate the building from the sky but the building changes perspective as the camera pans down.
    https://vimeo.com/66372643
    pw 1dc
    Can this be done all within AE, or do I need some 3rd party masking tool?
    The original is 4K.
    Thanks for any tips or suggestions.
    Local is the new global
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Ridley Walker replied 13 years, 3 months ago 3 Members · 4 Replies
  • Chris Brett
    May 17, 2013 at 9:59 am
    Hi Jim
    ————— if you are simply changing the sky then I reckon its worth trying a luma key / chroma key which I reckon will do most of it then you will just need to fiddle with the left hand corner a bit…..
    ——————————————— chris —
  • Ridley Walker
    May 17, 2013 at 3:10 pm
    Have you tried animating the mask shape?
    The shot doesn’t look to difficult to rotoscope in After Effects.
    Or use Mocha, see:https://library.creativecow.net/devis_andrew/AE_Rotoscoping-Mocha/1
  • Jim Bachalo
    May 17, 2013 at 7:12 pm
    Thanks! As a first step will try keying. If that doesn’t do the trick will give rotoscoping a try!
  • Ridley Walker
    May 17, 2013 at 8:38 pm
    Say hi to Rob Ford 😉
