Activity › Forums › Apple Final Cut Pro › changing settings to burn to dvd on new version 10.0.6
  • changing settings to burn to dvd on new version 10.0.6
    Posted by Heidi Schrodinger on October 31, 2012 at 3:20 am
    I need to do a simple thing, but can’t figure out how . Fisrt time I have used the upgrade since downloading it ( took a couple of weeks off from the computer when I finished my film- well worth it )
    I am burning a dvd from my final version of my film – and can no longer find a way to change the settings from 48k to 32 in audio. I gather I will need to do this as my audio was recorded and edited in 32. previous dvd burns prior to the upgrade were all fine, with setting changes so easy to find and use.
    I simply can not find a way to change the setting on the new share function FCPX has changed on us.
    damn annoying and holding me up.
    cheers,
    Heidi
    ‘Getting back into making after a long time off’
    Kyle Bass replied 13 years, 11 months ago 3 Members · 2 Replies
  • Michael Garber
    October 31, 2012 at 7:12 am
    I think you’ll be fine keeping the audio at 48k. Try it out first in a DVD to see.
    Michael Garber
    5th Wall – a post production company
  • Kyle Bass
    October 31, 2012 at 4:37 pm
    48 kHz is standard to the DVD spec. FCP should do the sample rate conversion for you. Otherwise, the audio (or maybe the whole disc) will most likely not work in a standard DVD player.
