Activity Forums Apple Final Cut Pro Legacy changing sequence settings
  • changing sequence settings
    Posted by Laura Rossi on November 9, 2009 at 6:44 pm
    Hi there!
    I need help
    I made a mistake, I worked with the wrong sequence setting and now I have to change it.
    My question is: is there a simple way to do this?
    I simply just tried to change the setting of the sequence when I finished but it is not going to work… Do I have to create a new sequence and reedit my work? 🙁
    please you saved my life many times.
    Thank you in advance
    L.
    Laura Rossi replied 16 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 9, 2009 at 6:48 pm
    Create a new sequence with the proper settings, then copy and paste everything from the bad into the new. You might need to fix some gaps (if the issue was different frame rate), or you might need to make sure all the clips SCALE and DISTORT are set to normal, if you had the clips in a sequence of differing size. REMOVE ATTRIBUTES works best…but if you have keyframed motion on clips, it will remove all of those, so you have to be careful.
    Shane
  • Laura Rossi
    November 9, 2009 at 6:49 pm
    Thank you thank you verY much!
    Laura
