Activity › Forums › Apple Final Cut Pro Legacy › Changing sequence settings in final cut after edit is done.
  • Changing sequence settings in final cut after edit is done.
    Posted by Jack Kemp on June 14, 2011 at 11:08 pm
    Hey guys,
    Now i have searched high and low for help on this but no one seems to be able to help. I hope you guys can.
    My problem is this:
    I have been assisting a director edit his work. Its a 90 minute feature film shot on RED 4K at 24 FPS. I have setup the sequence presets and everything to work with the RED proxys for a 2K reconform in the finishing stage of editing.
    Now I will admit I am not a high up editor, actually i rarely edit…just helping out where i can… so i am struggling abit with figuring this out myself. Anyway I had setup the sequences to editing in the Native RED proxys setup. However the Director gave me a heap of footage he had edited in a DV PAL 25p sequence. Now I have worked out away to reconform his stuff to PRORESS 422 (HQ) 25p…. however I need it to be PRORESS 422 (HQ) 24p. But when I try to swap it over FCP re edits my work but cutting clips in half and spaces in between and throws audio out of sync. Any idea on the steps I need to take to fix this mistake.
    Just to give you a heads up on what I am dealing with when i asked why he chose those setting he just said…. “I dunno, I just opened up the clips in FCP and started editing… that all i need to do right?”…. he has been using FCP since FCP studio 1. *slaps hand on forehead*
    Thanks guys I appreciate it.
    Brendan Maghran replied 15 years, 3 months ago 2 Members · 1 Reply
  • Brendan Maghran
    June 15, 2011 at 12:05 am
    Are you trying to continue the edit at 24p? You could export it out as a self contained QT, change the frame rate settings in Compressor.
