Activity › Forums › VEGAS Pro › Changing positions when rendering (event crop pan)
  • Changing positions when rendering (event crop pan)
    Posted by Gugliemo Hieronymus on September 22, 2012 at 5:57 pm
    Hi, I’m fairly new to the world of editing. I’ve been working on a project in my spare time for about 9 months, but still pretty bewlidered by a lot of the technical stuff. Having recently learned how to overlay different media on top of each other, I’ve now hit a problem when rendering. The media is moving around the screen.
    Here is the screen in preview (set to Best quality):
    https://s1122.photobucket.com/albums/l532/gugliemo/?action=view&current=photobucketpreview_zpsdfff9d5b.png
    The picture of arnie and the bold text under ‘crimewave’ are inserted jpegs.
    Here is the screen once rendered
    https://s1122.photobucket.com/albums/l532/gugliemo/?action=view&current=photobucketrendered_zpsc1ef2399.png
    Notice the writing and the picture have moved and the illusion is ruined.
    Now the most common problem for this seems to be different specs between video propreties and rendering. I checked and they were indeed wrong:
    The Project Video Properties were
    720 x 576
    The rendering properties were NTSC DV Widescreen (720 x 480)
    So I changed the rendering properties to PAL DV Widescreen (720×576)
    But the problem remained exactly the same! The rendered avi with matching specs still has the above boxes in the same wrong positions.
    Anybody know whats going on?
    Gugliemo Hieronymus replied 14 years ago 3 Members · 4 Replies
  • Steve Rhoden
    September 22, 2012 at 11:20 pm
    Seems like you have keyframes on the boxes as you are
    positioning them. Check to make sure none is there and disable
    the Sync Cursor button at the bottom.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Gugliemo Hieronymus
    September 23, 2012 at 3:26 pm
    Hi, I had keyframes turned on for a completely seperate shot, one which I had no problems with the positioning of. But just in case, I turned keyframes off for the entire file, and checked Sync Curser was disabled too. Still have the same problem when rendering.
  • Craig Meeks
    September 24, 2012 at 2:06 am
    Kinda sounds like keyframes to me too. It is entirely possible that you accidentally keyframed during pan/crop. I do it all the time. I would double check the position again in event pan/crop.
    If there are no keyframes there i’m not sure. Good luck.
    Craig Meeks
    Video Editor – South Coast Editing
    http://www.southcoastediting.com
    September 24, 2012 at 5:46 am
    I went through and rechecked that all the keyframes were off, which they are. However I’ve noticed a second possible clue:
    Although rendering the entire clip causes the boxes to appear in different positions, when I highlight only the problematic clip and select ‘preview in player’ the problem dissapears. This is the case regardless of whether I select NTSC DV Widesceen OR Pal DV Widescreen.
    But whatever setting I choose when rendering the entire project, the problem always occurs.
    Another clue: When I change the Project Video Properties to 720×480, the boxes in the preview screen move to where they appear in the full rendering.
    So to sum up
    – My project video settings are: 720×576
    – When I PREVIEW using either 720×576 *or* 720×480, the result concurs with the arrangement on the preview screen (576).
    – But when I RENDER the whole project, regardless of whether I do it as NTSC (480) or Pal (576) the result always appear in the wrong place, i.e. appears as 720×480.
    All keyframes are deselected, and the fact that the placement of the boxes precisely matches the preview screen *when* the preview settings are altered to 720×480 suggests to me that it is the aspect ratio.
    Any idea what’s going on??
