Activity Forums Apple Final Cut Pro Changing only the position of the connection?
  • Changing only the position of the connection?
    Posted by Wally Kouza on March 17, 2012 at 6:39 am
    Hi all,
    I’m trying to just change the position of the connection on the connected clip.
    Is there a way of doing that?
    For example, whenever I drag and drop a clip, the connection is always at the beginning but how do I change that position to the middle or the end without moving the clips position?
    Nick Ring replied 14 years, 6 months ago 2 Members · 3 Replies
  • Nick Ring
    March 17, 2012 at 7:11 pm
    Hover your cursor over the point in the connected clip that you want the connection to be moved to (may be handy to park the playhead there with snapping on), hold down cmnd-option and click.
  • Wally Kouza
    March 17, 2012 at 11:24 pm
    Amazing! It worked.
    Thanks a lot for the help!
  • Nick Ring
    March 18, 2012 at 5:39 pm
    Sure thing. I actually looked it up just the other day because I’d hit on the same problem.
