Activity Forums Adobe After Effects Expressions Changing object colour relating to values in json import
  • Changing object colour relating to values in json import
    Posted by Gary Sweeney on July 17, 2018 at 11:40 am
    I’m trying to create a heat map style graphic relating to the image below.
    I want each of the zones to change colour depending on values relating to a json import.
    Ideally the colour would change from green to red depending on the value, with 0 (min) being green and say 40 (max) being red.
    I have very limited knowledge of expressions and would appreciate any help.
    Thanks, Gary
    Scott Mcgee replied 8 years, 2 months ago 2 Members · 3 Replies
  • Scott Mcgee
    July 17, 2018 at 11:58 am
    I don’t know your layout for your Json, but this is the idea behind it. Also I’ve just copied and pasted the colours I used for a weather map. So you’ll want to look at what colour values you’d want.
    txt = footage(“file.json”).sourceData;
    input = txt.zone1
    if ( input <= 5 && input >= 0 ){
    ([0,255,210,255]/255)}
    else if ( input <= 10 && input >= 6 ){
    ([0,255,190,255]/255)}
    else if ( input <= 15 && input >= 11 ){
    ([0,255,170,255]/255)}
    else if ( input <= 20 && input >= 16 ){
    ([0,255,150,255]/255)}
    else if ( input <= 25 && input >= 21 ){
    ([232,255,0,255]/255)}
    else if ( input <= 30 && input >= 26 ){
    ([252,210,0,255]/255)
    }else{
    ([255,255,255,255]/255)};
    If you are clever about it, you could label your layers and use
    a = thisLayer.name
    input = txt[a]
    This would allow you to just copy and paste the expression onto all layers and you layer names will trigger that.
  • Gary Sweeney
    July 18, 2018 at 11:25 am
    Hi Scott,
    Thanks for the reply, I think I understand what you are saying, I’m just struggling to figure out how to link my json to the input part.
    I should’ve attached my json file in the last post, here is what I’m working with.
    12559_pitchmap.json.zip
    Zone 1 represents an individual receiving a ball & Zone 2 is where it goes.
    Sorry for the lack of knowledge, just starting to get my head around it.
  • Scott Mcgee
    July 20, 2018 at 8:10 am
    I noticed an issue with your json, which was it flagging issues for me when importing it? But it was the Zone: “One” and Zone: “Two”. It appeared to not like the “”, but after deleting and retyping it let me import it.
    otherwise this worked fine for me. Also I included the part that uses the layers name to reference it so you would only need to reference the array you want [0] or [1], based on your json layer.
    txt = footage(“pitchmap.json”).sourceData;
    a = thisLayer.name;
    input = txt[0][a];
    }else{
    Don’t forget when exporting you also need to put it onto the timeline otherwise the export will come out wrong.
