Activity Forums VEGAS Pro Changing Multiple Picture Durations
  • Changing Multiple Picture Durations
    Posted by Mark Prebonich on May 23, 2010 at 8:10 pm
    I have already placed multiple pictures on the timeline and gone thru and added pan/crop effects and fx effects. I found a different song that is of a different length that I would like to play the pictures with. Is there a way to adjust the length of all of the photos at once in order to make the entire collection the proper length? Thanks.
    -Mark
    Mike Kujbida replied 16 years, 3 months ago 3 Members · 5 Replies
  • Mike Kujbida
    May 23, 2010 at 10:46 pm
    Click the first image on the timeline, go to the end and Shift+click the last one and press ‘G’ to group the all together.
    Place the cursor at the end of the last image, hold down the Ctrl key (the cursor should change from a rectangle to a rectangle with a ~ under it) and drag it to the desired length.
  • Mark Prebonich
    May 24, 2010 at 2:21 am
    Thanks Mike for the help. I just got done resizing the picture montage and it worked great. 2 full songs to the project and all of the pictures are just the right length.
    -Mark
  • Mark Prebonich
    May 24, 2010 at 2:45 am
    Another related question Mike if you don’t mind. How do I adjust the transition times between the photos for the entire group? I would like to keep them all the same. Thanks
    -Mark
  • Aleksey Tarasov
    May 24, 2010 at 3:22 am
    Scripting tools like https://vegasaur.com/quick-properties (that I use) solve this issue with ease.
  • Mike Kujbida
    May 24, 2010 at 10:26 am
    Mark, Aleksey is correct in that a script is needed to do what you want to do as this isn’t a function that’s available in Vegas by itself.
    BTW, I’m glad to hear that my suggestion worked for you.
    I do a lot of slide shows and use this technique a lot.
